Does anyone else have an odd dark notch in the headlight low beam?
edge9421
Is it normal for my low beams to have a V shaped shadow? It’s been annoying me since I got my 2019 GT2 last March. It moves with the steering and covers the center stripe of the road so much it interferes with my ability to follow curves at night.
I tried to get a picture of it but it seems the notch varies with speed and maybe other factors. Its usually much bigger and the top edge of my beam seems much lower when I’m noticing it.
Yes, if ur in garage close you will see it much better, it's the top piece over the lense, is designed that way.
Wait, thought u were talking about the nouches at top of beam, sorry, never noticed that before but will look tomorrow
That notch is the separation between your headlights and your driver side headlight will be a little lower then your passenger side. The reason they do that is, why you have the car on low beams you don't blind on coming cars but you can still see far ahead.
St. Louis
2019 Stinger GT2 AWD
That drives me crazy! It's so distracting to me. It wouldn't be so bad if if stayed centered but it moves as you turn and I can't not notice it.
I haven't noticed it, I don't pay attention to my lights, I'm looking out for all the idiots on the road.
It bothered me at first but then I just got used to it
Doesn't bother me either and more importantly it prevents blinding incoming traffic.
The notch is there from the factory to prevent light bleed and potentially blinding other drivers. Them LED lights be too bright :cool:
edge9421
edge9421
I was thinking it might be to block light for oncoming cars, but the height of my overall beam pattern is so low it’s just covering the center stripe of the road and I can’t see down the road much at all. The fact it moves around when I’m steering is really distracting too.
Just asking but is your car at stock height?
edge9421
edge9421
Yes, stock height. Haven’t started doing any mods yet.
The reason why I ask is some guys that lower their cars don't reset the headlight height. Check you lights to make sure they're set at the right height from the factory, you never know!
AK
2018 Stinger GT2 AWD
I’ve noticed it, too. 2018 GT2 AWD.
tkb
east otis
2018 stinger
The headlights on my 2018 Stinger "Premium" are truly annoying - the odd notch being the one thing, however the absence of side-to-side adjustment and the "spotlight" they project into the trees with the highbeams is crazy. The right (passenger side) beam projects to the left, into oncoming traffic. Several visits to the dealer later, I was told this was normal !! The spotlight projected up at about a 15-20 angle into the trees is just useless.
I notice the V-notch everytime i drive at night. I have grown to ignore it.
Sent from my SM-A520W using Tapatalk
Welcome aboard @tkb
cclcal
San Diego
quest, model 3, 911.1
hello stinger owners, im in the market for a 2020 Sedona SX w LED DBL. Yes, I have googled sedona forums and no comment about it, but sedona forums are very quiet compared to this forum.
Ive noticed this dark spot/notch on 2018 and 2019 SX models w the LED DBL. Very annoying. Ive owned multiple cars and never had this issue. My 911 has dynamic headlights as well but no notches in the field of view. I'm worried the 2020 will have the notches. Most dealers have no idea what im talking about until we go on an evening test drive and then they notice it.
One dealer seemed to know, he called it "jagged illumination" and said 2020s do NOT have it. But the closest 2020 Sedona is 60 miles from me. Would hate to drive up there to make a deal and find out the headlights still have this issue.
Let me know if anyone has found a resolution to this.
Thanks!
Thanks!
I don’t think there is a resolution to it. Just a byproduct of the headlight design
Oh there is a resolution alright, take it to a customs shop, have them open up the headlight and remove the factory shroud, I did it with my 2015 Ford Fusion. I did not say was a cheap solution lol:)
