Smashed my mirror while reversing
torbach
Thread Starter #21
That's the spot.
Sent from my SM-G975U using Tapatalk
So this, or something like should prevent the air from getting in to the area causing noise. At first thought it was where the mirror moved, this is easy to fix.
Of course you have to remove the assembly again so be careful with the mirror, I broke my mirror. The OEM replacement was 257 bucks. I went with the 40 dollar option but I don't have blind side package so you won't have the cheaper option:)
Sent from my iPhone using Tapatalk Pro[/IMG]
torbach
Thread Starter #23
Thanks Chris. The image didn't come through on my side for some reason.
Do you remove the mirror from inside? By taking door panel off?
If you custom cut a piece of this it should block the noise. And should be thin enough to not notice
Oh, just Google thin rubber gaskets
torbach
Thread Starter #27
I didn't remove the entire mirror assembly. When I looked at that, there was a thick sheet of metal after the removal of the door trim that I wasn't sure I wanted to get into..
Other option is black gloss vinyl wrap, to cover the existing rubber gromet and just the front of the base to black the wind. They also sell thin rubber strips, you could custom cut a small black piece and glue to the rubber gromet already there. Or last you could try Permatex gasket maker and spread around base in very thin pattern or something like it. You just need an artist touch and it will likely not even be noticeable:)
However, I would remove the mirror, use the existing gromet as a guide and make my own:)
torbach
Thread Starter #29
Thanks a lot!
I looked at it again and it looks like the whole gasket is missing get something like this and wedge a piece in, test a few spots, bet you could get rid of noise pretty easy
torbach
Thread Starter #31
The gasket isn't missing. They inserted the gasket from the $300 eBay mirror. It was way worse before then. Still, I think your suggestion is the one that makes most sense if I don't take out the mirror in order to insert a custom gasket. I will try this. Thank you again!
torbach
Thread Starter #33
Let me know how it goes, good luck!
It worked. Thank you so much Chris. Wind noise is gone. Really, really appreciate the advice!
That's awesome bro!! I know how annoying that can be so I am happy for u!
I always back into my garage so that I'm pulling out when I'm in a hurry. LOL
But what if you have a teeny weeny tiny little garage like me. I can't back in because I wouldn't be able to see the tennis ball and stop the moment it touches the glass. Also can only get out in the middle. My wife's escape gets backed in because it's about 6" shorter so the beep beep beep backup sensor is good enough to get close enough to the wall for the door to shut. But yeah I've always dreaded this because my mirrors barely clear the garage door frame. The only car I've had that was easy peasy going in and out of this garage was the mini cooper
torbach
Thread Starter #36
This is what the suggested insulation looks like. It's unnoticeable unless you look closely. Thanks to @Chris71 it saved me $1k+.
That's a close up shot too, nice man!
KIA Stinger Forum Posts
