Kia OBD-II Error Codes
South Korea
Kia Stinger
P0100 Mass Air Flow or Volume Air Flow Circuit Malfunction.
P0101 Mass Air Flow or Volume Air Flow Circuit Range/Performance problem.
P0102 Mass Air Flow or Volume Air Flow Circuit Low Input.
P0103 Mass Air Flow or Volume Air Flow Circuit High Input.
P0107 MAP/BARO Circuit Low Input.
P0108 MAP/BARO Circuit High Input.
P0110 A/T Circuit Malfunction.
P0115 Engine Coolant Temperature Circuit Malfunction.
P0116 Engine Coolant Temperature Circuit Range/Performance Condition.
P0117 Engine Coolant Temperature Circuit Low Input.
P0118 Engine Coolant Temperature Circuit High Input.
P0120 Throttle Position Malfunction ? Circuit A.
P0122 APP/TPP Sensor Switch Low Input ? Circuit A.
P0123 APP/TPP Sensor Switch High Input ? Circuit A.
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control.
P0130 Oxygen Sensor Circuit Malfunction ? Bank 1 Sensor 1.
P0131 Oxygen Sensor Circuit Low Voltage ? Bank 1 Sensor 1.
P0132 Oxygen Sensor Circuit High Voltage ? Bank 1 Sensor 1.
P0133 Oxygen Sensor Circuit Slow Response ? Bank 1 Sensor 1.
P0134 Oxygen Sensor Circuit No Activity detected ? Bank 1 Sensor 1.
P0135 Oxygen Sensor Heater Circuit Malfunction ? Bank 1 Sensor 1.
P0136 Oxygen Sensor Circuit Malfunction ? Bank 1 Sensor 2.
P0137 Oxygen Sensor Circuit Low Voltage ? Bank 1 Sensor 2.
P0138 Oxygen Sensor Circuit High Voltage ? Bank 1 Sensor 2.
P0139 Oxygen Sensor Circuit Slow Response ? Bank 1 Sensor 2.
P0140 Oxygen Sensor Circuit No Activity detected ? Bank 1 Sensor 2.
P0141 Oxygen Sensor Heater Circuit Malfunction ? Bank 1 Sensor 2.
P0170 Fuel Trim Malfunction ? Bank 1.
P0171 System too Lean ? Bank 1.
P0172 System too Rich ? Bank 1.
P0261 Injector Circuit Low ? Cyl. 1.
P0262 Injector Circuit High ? Cyl. 1.
P0264 Injector Circuit Low ? Cyl. 2.
P0265 Injector Circuit High ? Cyl. 2.
P0267 Injector Circuit Low ? Cyl. 3.
P0268 Injector Circuit High ? Cyl. 3.
P0270 Injector Circuit Low ? Cyl. 4.
P0271 Injector Circuit High ? Cyl. 4.
P0300 Multiple/Random Misfire detected.
P0301 Misfire detected ? Cyls. 1-4.
P0302 Misfire detected ? Cyls. 1-4.
P0303 Misfire detected ? Cyls. 1-4.
P0304 Misfire detected ? Cyls. 1-4.
P0325 Knock Sensor Circuit Malfunction
P0326 Knock Sensor 1 Circuit Range/Performance ? Bank 1 or Single Sensor.
P0335 Crankshaft Position Sensor Malfunction ? Circuit A.
P0336 Crankshaft Position Sensor Range/Performance ? Circuit A.
P0340 Crankshaft Position Sensor Circuit Malfunction.
P0342 Crankshaft Position Sensor Circuit Low Input.
P0343 Crankshaft Position Sensor Circuit High Input.
P0400 EGR Flow Malfunction.
P0403 EGR Circuit Malfunction.
P0404 EGR Circuit Range/Performance Malfunction.
P0420 Catalyst System Efficiency below Threshold ? Bank 1.
P0422 Main Catalyst Efficiency below Threshold ? Bank 1.
P0440 Evaporative Control Malfunction.
P0441 Evaporative Control System ? Improper Purge.
P0442 Evaporative Control System ? Small Leak detected.
P0443 Evaporative Control System Purge Control Valve Circuit Malfunction.
P0446 Evaporative Vent Control Circuit Malfunction.
P0447 Evaporative Vent Control Circuit Open.
P0448 Evaporative Vent Control Circuit Short.
P0450 Evaporative System Pressure Sensor Circuit Malfunction.
P0452 Evaporative Control System Pressure Sensor Low Input.
P0453 Evaporative Control System Pressure Sensor High Input.
P0455 Evaporative Control System ? Large Leak detected.
P0470 Exhaust Pressure Sensor Malfunction.
P0500 Vehicle Speed Sensor Malfunction.
P0501 Vehicle Speed Sensor Range/Performance.
P0505 Idle Air Control System Malfunction.
P0506 Idle Air Control System Malfunction ? RPM Lower than expected.
P0507 Idle Air Control System Malfunction ? RPM Higher than expected.
P0510 CTP Switch Malfunction.
P0561 System Voltage Unstable.
P0562 System Voltage Low.
P0563 System Voltage High.
P0601 Internal Control Module Memory Checksum Error.
P0604 Internal Control Module RAM Error.
P0703 Torque Converter/Brake Pedal Switch Malfunction ? Circuit B.
P0705 Transaxle Range Sensor Circuit Malfunction (PRNDL Input).
P0706 A/T Range Sensor Circuit Range/ Performance.
P0710 Transaxle Fluid Temperature Sensor Circuit Malfunction.
P0711 A/T Fluid Temperature Sensor Circuit Range/Performance.
P0715 Input/Turbine Speed Sensor Circuit Malfunction.
P0722 Output Speed Sensor Circuit No Signal.
P0726 Engine Speed Input Circuit Range/ Performance.
P0727 Engine Speed Input Circuit ? No Signal.
P0731 A/T Gear 1 Improper Ratio.
P0732 A/T Gear 2 Improper Ratio.
P0733 A/T Gear 3 Improper Ratio.
P0734 A/T Gear 4 Improper Ratio.
P0740 Torque Converter Clutch System Malfunction.
P0743 Torque Converter Clutch Circuit Electrical.
P0750 Shift Solenoid ?A? Malfunction.
P0753 Shift Solenoid ?A? Electrical.
P0755 Shift Solenoid ?B? Malfunction.
P0758 Shift Solenoid ?B? Electrical.
P0760 Shift Solenoid ?C? Malfunction.
P1000 Readiness Function Code.
P1115 Engine Coolant Temperature Signal from ECM to TCM.
P1121 Throttle Position Sensor Signal Malfunction from ECM to TCM.
P1170 Front Heated Oxygen Sensor Stuck.
P1195 EGR Pressure Sensor (1.6L) or Boost Sensor (1.8L) Open or Short.
P1196 Ignition Switch ?Start? Open or Short (1.6L).
P1250 Pressure Regulator Control Solenoid Valve Open or Short.
P1252 Pressure Regulator Control Solenoid Valve No. 2 Circuit Malfunction.
P1307 Chassis Acceleration Sensor Signal Malfunction.
P1308 Chassis Acceleration Sensor Signal Low.
P1309 Chassis Acceleration Sensor Signal High.
P1345 No SGC Signal (1.6L).
P1386 Knock Sensor Control Zero Test.
P1402 EGR Valve Position Sensor Open or Short.
P1449 Canister Drain Cut Valve Open or Short (1.8L).
P1450 Excessive Vacuum Leak.
P1455 Fuel Tank Sending Unit Open or Short (1.8L).
P1457 Purge Solenoid Valve Low System Malfunction.
P1458 A/C Compressor Control Signal Malfunction.
P1485 EGR Solenoid Valve Vacuum Open or Short.
P1486 EGR Solenoid Valve Vent Open or Short.
P1487 EGR Boost Sensor Solenoid Valve Open or Short.
P1496 EGR Stepper Motor Malfunction ? Circuit 1 (1.8L).
P1497 EGR Stepper Motor Malfunction ? Circuit 2 (1.8L).
P1498 EGR Stepper Motor Malfunction ? Circuit 3 (1.8L).
P1499 EGR Stepper Motor Malfunction ? Circuit 4 (1.8L).
P1500 No Vehicle Speed Signal to TCM.
P1505 Idle Air Control Valve Opening Coil Voltage Low.
P1506 Idle Air Control Valve Opening Coil Voltage High.
P1507 Idle Air Control Valve Closing Coil Voltage Low.
P1508 Idle Air Control Valve Closing Coil Voltage High.
P1523 VICS Solenoid Valve.
P1586 A/T-M/T Codification.
P1608 PCM Malfunction.
P1611 MIL Request Circuit Voltage Low.
P1614 MIL Request Circuit Voltage High.
P1624 MIL Request Signal from TCM to ECM.
P1631 Alternator ?T? Open or No Power Output (1.8L).
P1632 Battery Voltage Detection Circuit for Alternator Regulator (1.8L).
P1633 Battery Overcharge.
P1634 Alternator ?B? Open (1.8L).
P1693 MIL Circuit Malfunction.
P1743 Torque Converter Clutch Solenoid Valve Open or Short.
P1794 Battery or Circuit Failure.
P1795 4WD Switch Signal Malfunction.
P1797 P or N Range Signal or Clutch Pedal Position Switch Open or Short.
Sweet, thanks for the info. Make this thread a sticky if it isn't.
mdixon18
Victorville
2018 Kia Stinger
I have a 2018 Kia Stinger 3.3l my check engine light is on its not blinking its on solid .my screen says engine control system i connected a obd. 2 reader and it gives me code P0172 the car lost power picks up speed very slow..Any help would really help. Thank You.
mdixon18
Victorville
2018 Kia Stinger
By the way its a 2.0l kia stinger not a 3.3l
MONUSA
Lexington
KY
2018 Stinger 2.0T
Yes....have you installed any "mods"???? i.e. intake, plugs, exhaust.......tune.........etc...
mdixon18
Victorville
2018 Kia Stinger
No everything is stock just like i got it from the dealership]
Denver
18 stinger got
Has anyone encountered 0014 ? Having trouble finding information on it ....
18 AWD stinger gt jb4 map 1 intakes catch can no other mods any help appreciated !
Reset the code so there's no codes showing, disconnect the battery for 15 minutes an after you reconnect the battery see if it shows up again. If it does show up again go through those steps again this time disconnect the jb4 an see if it shows up again if it doesn't show up it's the firmware for the jb4, get ahold of Terry with Burger Motorsports.. Are you running the latest firmware on the jb4?
Oxford
CT
2021 GT2 RWD (SWP)
Hey im getting a P0050 code. I clear the codes by doing the following (as directed by someone at JB4). Hit the start engine button three times without touching the brake, hit the delete codes button in the app. I start the car and the check engine light is gone. However every single time i shut the car off again and restart, the light comes back on. Also, when the check engine light is on, my drive modes do not work. When i clear the light and code they work again. The guy at JB4 had me send him the following logs. Can someone help me out? JB4 has not responded to me since sending my logs later in the night on 4/1. Still getting the light as of now.
I am going to try to unplug the JB4 and see if the code still comes up. SHould i be removing the battery when installing or un-installing the JB4?
Unplug the JB4, delete the code, drive the car for a couple of days an if no code it's the JB4 setting the code off. Call BMS an talk to Terry Burger, you can disconnect the negative terminal to connect the JB4. Went you connect the JB4 make sure ALL the connections are connected right.
Valley Center
2018 Stinger GT2
Similar issue... P0597 (thermostat circuit open), so I replaced the thermostat (not an fun job). Still shows the error. I sent logs to Burger and they said it's a bad fuel wire. I went through it for the 1000th time and it's installed perfectly as described in the manual. It works, we definitely get more boost when in Map 1 (we are CA so 91 OCT is all we have )... I can get rid of the check engine and then it's off until we stop and start again. We had no issues until we installed JB4. So I uninstalled it just to see.. still get the light, so now I need to track down the electrical and I can't find a schematic to save my life.
