- 4
- Reactions
- 2
- City
- Fort Worth
- TX
- What I Drive
- 2019 Base 2.0 W/O Premium
I just completed a 2.0 base 6 speaker system to the Harmon Kardon 15 speaker system and 8" display. It took me 3 months to complete. I did not take pictures of the process. But what I had to buy: Head unit, display, all 4 door cards, 4 HK door speakers, 2 HK subs, and the HK amplifier w/pigtails, 25ft wire x 28 some 22ga(comms) some 18ga(speakers), head unit sub adapter (for the wires to cut), center dash speaker HK, center dash cover with speaker hole, fuse block for 4 fuses for power to amp, and 8" display surround panel above dash pad.
This was not an easy or cheap task. I only did the task because I am stubborn and was not going to let the car win. I also did not want the Sun and Sound package. I don't like sunroofs.
Tasks that had to be completed:
Remove both seats, throttle pedal, console, dash pad, all lower interior trim, bottom of rear seat and RH rear portion of rear seat for wiring. Cut holes in carpet for OEM subs, remove foam that was original taking up the subs space, and cut holes in the interior rocker arms for the porting of the subs into the frame. Then rewire 4 of the door card speakers from the amp in the trunk/hatch to the back of the head unit where the original harness ran the 4 original outputs. I had to splice the CAN high and low wires, nav voice, Ignition and Accessory wires to the amp in rear. Run wires from the head unit for digital audio + and -. Ran center dash speaker and the original 4 channels to the doors up to the head unit. I then ran one set of wires for each new door panel channels, and both sets of sub wires to the amp in rear.
Although it is a 15 speaker system there are only 11 channels. Each of the doors use the same channel for the mid's and tweeters.
Below is a link to the add 2ch sub connector that I used for much of my splicing. I removed the amp addon portion of device and only used the connectors and wires.
https://www.ebay.com/itm/1433272901...ke:Kia&hash=item215ef8e30b:g:RB8AAOSw2bRd~a2l
All of the other Items were OEM and bought mostly though ebay.
Here is where I had trouble:
1.My door panels had acoustic lighting. The HK panels did not and could not change them without removing the ultrasonic welds on the door panels. I opted to abandon the acoustic lighting on the doors.
2.The driver door and front passenger doors have the exact same number of buttons on them as the HK door switch panel and look identical. But they would not function proper when plugged in and I moved the original equipped switch panels to the HK door cards. All functions worked after that. The part numbers were different on each switch panel.
3.Running wires into the doors. Front doors I ran the wires though a small circle port in the door disconnect and did not make the wires disconnect. On the rear doors I drilled a very small hole in the rubber boot for the wiring and a small hole in a plug on the chassis and did not make the wires disconnect.
4.Cutting the holes in the rocker panels. VERY VERY difficult. The metal is hardened and did not cut easily. There is not one picture online of the hole placement. I had to guess a little. I used a Dremmel to cut the holes but It is very tight in the floor.
5.The amp has 4 battery (+) cables and 4 (-) cables. I added a fuse block at the battery and added four 5amp fuses for the power to the amp, not necessary but I chose this way. I also used 8 ga. power wire to the fuse panel I added.
6.some of the pin outs from the amp are not correct. Where it lists surround - those are the mid and tweeters in the rear. and Center door speaker is the Dash speaker.
I also upgraded my dash to the supervision 180mph speedometer from a 3.3L. I had it programmed to remove the unnecessary features. I found that the torque, boost and oil temp gauges work with the supervision as did the g meter and compass.
It took three months because of weather and waiting for all parts. I was not in a hurry.
