Tire replacement wear front to rear
Ontario
2018 Genesis G90 Premium 3.3T AWD
Found my rear tires are at the tread wear indicator level and need replacement. The front tires measure 7/32 and 6/32" each. Should I replace all four or just the rear two tires? I searched the owners manual but can't find any information on the subject. Thanks
If you can afford to replace all 4 do that
F
Ontario
Thanks, i was leaning towards replacing all four as replacing just two would cause me to be in constant concern that I was harming the drivie line and AWD system.
