Kia Stinger Technical Specifications
KiaFan
2018 Kia Stinger
Cargo Area Dimensions
Trunk Volume: N/A ft3
Tires
Front Tire Order Code:
Rear Tire Order Code:
Spare Tire Order Code:
Front Tire Size: P225/45VR18
Rear Tire Size: P225/45VR18
Spare Tire Size: Compact
Exterior Dimensions
Wheelbase: 114.4 in
Length, Overall: 190.2 in
Width, Max w/o mirrors: 73.6 in
Height, Overall: 55.1 in
Track Width, Front: 62.8 in
Track Width, Rear: 64.8 in
Min Ground Clearance: N/A in
Liftover Height: N/A in
Vehicle
EPA Classification: Large Cars
Mileage
EPA Fuel Economy Est - Hwy: 29 MPG
Cruising Range - City: 349.80 mi
EPA Fuel Economy Est - City: 22 MPG
Fuel Economy Est-Combined: 25 MPG
Cruising Range - Hwy: 461.10 mi
EPA MPG Equivalent - City: N/A
EPA MPG Equivalent - Hwy: N/A
EPA MPG Equivalent - Combined: N/A
Battery Range: N/A mi
Suspension
Suspension Type - Front: Strut
Suspension Type - Rear: Multi-Link
Suspension Type - Front (Cont.): Strut
Suspension Type - Rear (Cont.): Multi-Link
Shock Absorber Diameter - Front: N/A mm
Shock Absorber Diameter - Rear: N/A mm
Stabilizer Bar Diameter - Front: N/A in
Stabilizer Bar Diameter - Rear: N/A in
Steering
Steering Type: Rack-Pinion
Steering Ratio :)1), Overall: N/A
Lock to Lock Turns (Steering): N/A
Turning Diameter - Curb to Curb: 36.7 ft
Turning Diameter - Wall to Wall: N/A ft
Interior Dimensions
Passenger Capacity: 5
Passenger Volume: 93.8 ft3
Front Head Room: 38.3 in
Front Leg Room: 42.6 in
Front Shoulder Room: 56.4 in
Front Hip Room: 55.5 in
Second Head Room: 37 in
Second Leg Room: 36.4 in
Second Shoulder Room: 54.8 in
Second Hip Room: 56.1 in
Emissions
Tons/yr of CO2 Emissions @ 15K mi/year: 7.0
EPA Greenhouse Gas Score: N/A
Wheels
Front Wheel Size: 18 X 8 in
Rear Wheel Size: 18 X 8 in
Spare Wheel Size: Compact in
Front Wheel Material: Aluminum
Rear Wheel Material: Aluminum
Spare Wheel Material: Aluminum
Fuel Tank
Fuel Tank Capacity, Approx: 15.9 gal
Aux Fuel Tank Capacity, Approx: N/A gal
Engine
Engine Order Code:
Engine Type: Intercooled Turbo Premium Unleaded I-4
Displacement: 2.0 L/122
Fuel System: Gasoline Direct Injection
SAE Net Horsepower @ RPM: 255 @ 6200
SAE Net Torque @ RPM: 260 @ 1400
Transmission
Drivetrain: Rear Wheel Drive
Trans Order Code:
Trans Type: 8
Trans Description Cont.: Automatic w/OD
Trans Description Cont. Again:
First Gear Ratio :)1): 3.96
Second Gear Ratio :)1): 2.47
Third Gear Ratio :)1): 1.61
Fourth Gear Ratio :)1): 1.18
Fifth Gear Ratio :)1): 1.00
Sixth Gear Ratio :)1): 0.83
Reverse Ratio :)1): 2.27
Clutch Size: N/A in
Final Drive Axle Ratio :)1): 3.73
Seventh Gear Ratio :)1): 0.65
Eighth Gear Ratio :)1): 0.56
Weight Information
Base Curb Weight: N/A lbs
Cooling System
Total Cooling System Capacity: N/A qts
Brakes
Brake Type: N/A
Brake ABS System: 4-Wheel
Brake ABS System (Second Line): N/A
Disc - Front (Yes or ): Yes
Disc - Rear (Yes or ): Yes
Front Brake Rotor Diam x Thickness: 12.6 in
Rear Brake Rotor Diam x Thickness: 12.4 in
Drum - Rear (Yes or ):
Rear Drum Diam x Width: in
Trailering
Dead Weight Hitch - Max Trailer Wt.: N/A lbs
Dead Weight Hitch - Max Tongue Wt.: N/A lbs
Wt Distributing Hitch - Max Trailer Wt.: N/A lbs
Wt Distributing Hitch - Max Tongue Wt.: N/A lbs
Electrical
Cold Cranking Amps @ 0? F (Primary): 740
Maximum Alternator Capacity (amps): 150
2018 Kia Stinger GT
Trunk Volume N/A ft3
Tires
Front Tire Size P225/40VR19
Rear Tire Size P255/35VR19
Spare Tire Size Compact
Exterior Dimensions
Wheelbase 114.4 in
Length, Overall 190.2 in
Width, Max w/o mirrors 73.6 in
Height, Overall 55.1 in
Track Width, Front 62.8 in
Track Width, Rear 63.7 in
Min Ground Clearance N/A in
Liftover Height N/A in
Vehicle
EPA Classification Large Cars
Mileage
EPA Fuel Economy Est - Hwy 25 MPG
Cruising Range - City 302.10 mi
EPA Fuel Economy Est - City 19 MPG
Fuel Economy Est-Combined 21 MPG
Cruising Range - Hwy 397.50 mi
EPA MPG Equivalent - City N/A
EPA MPG Equivalent - Hwy N/A
EPA MPG Equivalent - Combined N/A
Battery Range N/A mi
Suspension
Suspension Type - Front Strut
Suspension Type - Rear Multi-Link
Suspension Type - Front (Cont.) Strut
Suspension Type - Rear (Cont.) Multi-Link
Shock Absorber Diameter - Front N/A mm
Shock Absorber Diameter - Rear N/A mm
Stabilizer Bar Diameter - Front N/A in
Stabilizer Bar Diameter - Rear N/A in
Steering
Steering Type Rack-Pinion
Steering Ratio :)1), Overall N/A
Lock to Lock Turns (Steering) N/A
Turning Diameter - Curb to Curb 38.4 ft
Turning Diameter - Wall to Wall N/A ft
Interior Dimensions
Passenger Capacity 5
Passenger Volume 93.8 ft3
Front Head Room 38.3 in
Front Leg Room 42.6 in
Front Shoulder Room 56.4 in
Front Hip Room 55.5 in
Second Head Room 37 in
Second Leg Room 36.4 in
Second Shoulder Room 54.8 in
Second Hip Room 56.1 in
Emissions
Tons/yr of CO2 Emissions @ 15K mi/year 8.4
EPA Greenhouse Gas Score N/A
Wheels
Front Wheel Size 19 X 8 in
Rear Wheel Size 19 X 8.5 in
Spare Wheel Size Compact in
Front Wheel Material Aluminum
Rear Wheel Material Aluminum
Spare Wheel Material Aluminum
Fuel Tank
Fuel Tank Capacity, Approx 15.9 gal
Aux Fuel Tank Capacity, Approx N/A gal
Engine
Engine Order Code
Engine Type Twin Turbo Premium Unleaded V-6
Displacement 3.3 L/204
Fuel System Gasoline Direct Injection
SAE Net Horsepower @ RPM 365 @ 6000
SAE Net Torque @ RPM 376 @ 1300
Transmission
Drivetrain All Wheel Drive
Trans Order Code
Trans Type 8
Trans Description Cont. Automatic w/OD
First Gear Ratio :)1) 3.67
Second Gear Ratio :)1) 2.40
Third Gear Ratio :)1) 1.61
Fourth Gear Ratio :)1) 1.19
Fifth Gear Ratio :)1) 1.00
Sixth Gear Ratio :)1) 0.83
Reverse Ratio :)1) 2.27
Clutch Size N/A in
Final Drive Axle Ratio :)1) 3.54
Seventh Gear Ratio :)1) 0.64
Eighth Gear Ratio :)1) 0.56
Weight Information
Base Curb Weight N/A lbs
Cooling System
Total Cooling System Capacity N/A qts
Brakes
Brake Type N/A
Brake ABS System 4-Wheel
Brake ABS System (Second Line) N/A
Disc - Front (Yes or ) Yes
Disc - Rear (Yes or ) Yes
Front Brake Rotor Diam x Thickness 13.8 in
Rear Brake Rotor Diam x Thickness 13.4 in
Rear Drum Diam x Width in
Trailering
Dead Weight Hitch - Max Trailer Wt. N/A lbs
Dead Weight Hitch - Max Tongue Wt. N/A lbs
Wt Distributing Hitch - Max Trailer Wt. N/A lbs
Wt Distributing Hitch - Max Tongue Wt. N/A lbs
Electrical
Cold Cranking Amps @ 0? F (Primary) 740
Maximum Alternator Capacity (amps) 150
