Kia Stinger muffler delete sound
#42
Just an update on my exhaust. Wasnt able to upload a video. But, you can check out the video I uploaded on my yotube channel??
[MENTION=885]Jays_stinger[/MENTION], you should be able to insert the link to the youtube video.
18 Stinger GT2 RWD White
#43
[MENTION=863]pixeltim[/MENTION]
No. I just had them cut from the edge of the muffler and add new piping. Didn't add Y pips since there's no reason... So only 1 pipe on each end in the center
Perfect mod to for an aggressive sound not obnoxious either ????
Hey Jay, Did you by chance take any pics? I really want to get this done, I'd just like to know exactly what to tell them to do.
2018 Kia Stinger GT Micro Blue
#44
All you need to let then know you want done is resonator and muffler deletes. Also, you dont need y-pipes the single piping theyll add is fine. (Theyll charge tou more for y pipes. Probably 40$ or more for each one.
I called a local shop and they said that some kits include an X or H-pipe, any thoughts on those?
AK
I know this is the wrong forum, but does anyone know what this would sound like on a 2.0? That’s about my only complaint with this car... it’s too quiet.
Should give you a nice rumble.
I purchased these off of Ebay. They're 4" tips with Carbon fiber covers. They're about 150$
Do these mount to the bumper since you don’t have y pipes? I’ve seen some on other threads but they clamp to the exhaust.
#50
My exhaust tips are single inlets... So it attaches to my single exhaust pipes it was clamped and welded .
Gotcha, so I take it yours are duals then, the other thread was looking at 4 singles for the stock exhaust. Did you have to shave down the holes in the bumper at all to get them to fit?
#52
Yes dual tips on each side. Yes, I shaved the inside of the bumper and a straight cut so they could fit without any issues.
#55
Yes, I noticed a bit more drone. It's fine while cruising. I hear it more when I start pressing on the throttle.
Do you think the added sound is worth the extra drone?
#57
For my preference yes. Way better sound than just a muffler delete. I can live with the drone it has.
Mine are a bit smaller so I only had to dremel a small portion on the top and bottom without cutting through the entire bumper
Il post a full rear picture soon. I just had to wash the car since it was so dirty
What size tips are those? And did you order from aliexpress?
51 mm inlet x 89mm outlet. Smallest size they carry but its just right. Ordered through DHGate which is basically the same principal
