2018 Kia Stinger Specifications
StingerMike
Engine
[table="width: 1000"]
[tr]
[td][/td]
[td]Stinger[/td]
[td]Stinger GT[/td]
[/tr]
[tr]
[td]Type/layout [/td]
[td]2.0L Turbo Charged I4 Theta II [/td]
[td]3.3L Twin Turbo V6 Lambda II [/td]
[/tr]
[tr]
[td]Horsepower (est.) [/td]
[td]255 hp @ 6,200 rpm [/td]
[td]365 hp @ 6,000 rpm [/td]
[/tr]
[tr]
[td]Torque (est.) [/td]
[td]260 lb.-ft @ 1,400-4,000 rpm [/td]
[td]376 lb.-ft @ 1,300-4,500 rpm [/td]
[/tr]
[tr]
[td]Block [/td]
[td] Aluminum [/td]
[td] Aluminum [/td]
[/tr]
[tr]
[td]Head [/td]
[td]Aluminum [/td]
[td]Aluminum [/td]
[/tr]
[tr]
[td]Valve System [/td]
[td]DOHC D-CVVT 16V [/td]
[td]DOHC D-CVVT 24V [/td]
[/tr]
[tr]
[td]Displacement (cc) [/td]
[td]1,998 cc [/td]
[td]3,342 cc [/td]
[/tr]
[tr]
[td]Bore x stroke (mm) [/td]
[td]86.0 mm X 86.0 mm [/td]
[td] 92.0 mm x 83.8 mm [/td]
[/tr]
[tr]
[td]Compression ratio [/td]
[td]10.0:1 [/td]
[td]10.0:1 [/td]
[/tr]
[tr]
[td]Fuel System [/td]
[td]GDI (Gasoline Direct Injection) [/td]
[/tr]
[tr]
[td]Fuel Requirement [/td]
[td]Premium Recommended [/td]
[/tr]
[/table]
Drivetrain
[tr]
[td][/td]
[td]Stinger[/td]
[td]Stinger GT[/td]
[/tr]
[tr]
[td]Transmission Gear Ratios [/td]
[td]8-speed automatic transmission [/td]
[/tr]
[tr]
[td]First [/td]
[td] 3.964:1 [/td]
[td] 3.665:1 [/td]
[/tr]
[tr]
[td]Second [/td]
[td]2.468:1 [/td]
[td]2.396:1 [/td]
[/tr]
[tr]
[td]Third[/td]
[td] 1.610:1 [/td]
[td] 1.610:1 [/td]
[/tr]
[tr]
[td]Fourth[/td]
[td]1.176:1 [/td]
[td]1.190:1 [/td]
[/tr]
[tr]
[td]Fifth [/td]
[td]1.000:1 [/td]
[td]1.000:1 [/td]
[/tr]
[tr]
[td]Sixth [/td]
[td]0.832:1 [/td]
[td]0.826:1 [/td]
[/tr]
[tr]
[td]Seventh[/td]
[td]0.652:1 [/td]
[td] 0.643:1 [/td]
[/tr]
[tr]
[td]Eighth [/td]
[td] 0.565:1 [/td]
[td] 0.556:1 [/td]
[/tr]
[tr]
[td]Eighth [/td]
[td] 0.565:1 [/td]
[td]0.556:1 [/td]
[/tr]
[tr]
[td]Reverse[/td]
[td]2.273:1 [/td]
[td]2.273:1 [/td]
[/tr]
[tr]
[td]Final gear ratio [/td]
[td] 3.727:1 [/td]
[td]3.538:1 [/td]
[/tr]
[tr]
[td]Layout/drive[/td]
[td]Front Engine/ Rear or All Wheel Drive [/td]
[/tr]
[/table]
Exterior Dimensions
[tr]
[td][/td]
[td]Stinger[/td]
[td]Stinger GT[/td]
[/tr]
[tr]
[td]Length (in.) [/td]
[td]190.2 in. [/td]
[td]190.2 in. [/td]
[/tr]
[tr]
[td]Width (in.) [/td]
[td] 73.6 in. [/td]
[td] 73.6 in. [/td]
[/tr]
[tr]
[td]Height (in.) [/td]
[td] 55.1 in. [/td]
[td] 55.1 in. [/td]
[/tr]
[tr]
[td]Wheelbase (in.) [/td]
[td] 114.4 in. [/td]
[/tr]
[tr]
[td]Overhang, front/rear (in.) [/td]
[td] 32.7 in. / 43.1 in. [/td]
[/tr]
[/table]
Interior Dimensions
[tr]
[td][/td]
[td]Stinger[/td]
[td]Stinger GT[/td]
[/tr]
[tr]
[td]Seating capacity [/td]
[td]5 passenger [/td]
[/tr]
[tr]
[td]Head room Front (in.) [/td]
[td]39.4 in. [/td]
[td]39.4 in. [/td]
[/tr]
[tr]
[td]Leg room Front (in.) [/td]
[td]42.6 in. [/td]
[td]42.6 in.[/td]
[/tr]
[tr]
[td]Leg room Rear (in.)[/td]
[td]36.4 in. [/td]
[td]36.4 in. [/td]
[/tr]
[tr]
[td]Shoulder room Front (in.) [/td]
[td] 56.4 in. [/td]
[td] 56.4 in. [/td]
[/tr]
[tr]
[td]Shoulder room Rear (in.) [/td]
[td] 54.8 in. [/td]
[td] 54.8 in. [/td]
[/tr]
[/table]
Chassis/Suspension
[tr]
[td][/td]
[td]Stinger[/td]
[td]Stinger GT[/td]
[/tr]
[tr]
[td]Front suspension [/td]
[td]MacPherson [/td]
[/tr]
[tr]
[td]Rear suspension [/td]
[td] Multi Link (5-link) [/td]
[/tr]
[tr]
[td]Construction[/td]
[td] Steel Unibody [/td]
[/tr]
[/table]
Steering
[tr]
[td][/td]
[td]Stinger[/td]
[td]Stinger GT[/td]
[/tr]
[tr]
[td]Type / Power source [/td]
[td]Rack and Pinion / Electric motor [/td]
[td]Rack and Pinion / Electric motor[/td]
[/tr]
[tr]
[td]Variable Gear Ratio [/td]
[td]Constant [/td]
[td]Variable[/td]
[/tr]
[tr]
[td]Turns, lock-to-lock (FWD) [/td]
[td]2.4 [/td]
[td]2.4 [/td]
[/tr]
[tr]
[td]Turns, lock-to-lock (AWD) [/td]
[td]2.3 [/td]
[td]2.3 [/td]
[/tr]
[tr]
[td]Turning circle, curb-to-curb (ft.) (FWD) [/td]
[td] 36.9 ft. [/td]
[td] 36.9 ft. [/td]
[/tr]
[tr]
[td]Turning circle, curb-to-curb (ft.) (AWD) [/td]
[td] 37.5 ft. [/td]
[td] 37.5 ft. [/td]
[/tr]
[/table]
Brakes
[tr]
[td][/td]
[td]Stinger[/td]
[td]Stinger GT[/td]
[/tr]
[tr]
[td]Type front/rear [/td]
[td]Ventilated disc / Disc [/td]
[td]Brembo 4-Piston Caliper Ventilated Disc / Brembo 2-Piston Caliper Ventilated Disc [/td]
[/tr]
[tr]
[td]Size (in.) front/rear [/td]
[td]12.6 in. / 12.4 in. [/td]
[td]13.8 in. / 13.4 in. [/td]
[/tr]
[/table]
Wheels/Tires
[tr]
[td][/td]
[td]Stinger[/td]
[td]Stinger GT[/td]
[/tr]
[tr]
[td]Wheel size (in.) [/td]
[td] 8.0Jx18 [/td]
[td]8.0Jx19 (front) / 8.5Jx19 (rear) [/td]
[/tr]
[tr]
[td]Tire size [/td]
[td]P225/45R18 [/td]
[td]P225/40R19 (Front) / P255/35R19 (Rear) [/td]
[/tr]
[tr]
[td]Spare Tire[/td]
[td]Compact Spare [/td]
[/tr]
[/table]
Kia Stinger Spare Tyre, Kia Stinger Spare wheel
Great job Mike. This is very useful.
TRD
Agreed, answered a question I had about the spare as well.
SeoulStinger
2015 Audi A6
Another useful spec is curb weight.
2.0T = 1650 kg / 3640 lbs
GT = 1850 kg / 4080 lbs
BobFr
AL
2008 Mitsubishi Evolution MR
SeoulStinger, thanks for this spec. Do you know if these are the weights for the RWD or AWD?
It would be nice to know the ground clearance, but nice post.
