Turn on 12V auxillary ports when ignition is off
Colin
Hello All, I have Stinger GT 2 and have fitted a camera to the windscreen which I want to power from the 12V auxiliary port in the front. I would like the camera to keep running when I am not in the vehicle as it is movement activated, so will not drag from the battery when not in use. The problem with the auxiliary ports is when the ignition is off, so is the power to them. Would anyone know if there is a setting in a menu, or wherever that could fix my problem? I can't use the existing USB port as I need that for that hopeless app Android Auto.
Thanks for reading this and hope you can help.
