RPM shaking and Check engine sign flashing and suddenly everything back to normal
Turki1
Riyadh
Saudi Arabia
Kia Stinger 3.3L 2018
It started a long time ago when the car start shaking when I am not driving and the engine is on for couple of seconds and it backs to normal Idle RPM, and this is occurs once in while and it increases with time until now it happen in daily bases, the car start to shaking and sometimes the RPM start to be around 1200RPM without pressing the gas paddle and the most painful thing that now the engine sign start to flashing when this thing occurs for couple of minutes and for all of sudden everything goes back to normal and sometime require to stop the engine and turn it on again and comes back to normal. I got the JB4 installed and After market spark plugs gapped with the right measures and it happend before I install a new one and after I changed it so, It not spark plugs problem, I checked the throttle gate and its clean, I cleaned the MAF sensors because there is to of them. I checked the JB4 if I can get any codes when the check engine sign pops but It not showing any code
SO I do not know where to look at to solve this problem
I disconnected the JB4 fully and the problem is still there so It not a matter of JB4, some people say its the spark plugs gapping its not correct and it needs to be tight in precise way and specific torque but I do not think so
I installed Injen intake and I checked the hoses and all is good
It might be the Oxygen sensor Or the camshaft sensor Or the the MAF sensors! but I couldn't say where to start
I know its a matter of something related to air flow and sensors or something close to this things
any thoughts guys?
