multimedia screen 2019
2018 Kia Stinger Limited
I would like to replace my 2017 screen
Isn't this covered under warranty?
What is wrong with the screen that makes you want to replace it?
Did you already check with the dealer? This is likely a dealer only part.
If you’re wanting to replace your current one with the newer larger screen I suggest you keep an eye on eBay. As for installing it, better make good friends with your local Kia service advisor
jojorodrigues
Switzerland
I wanted to change against that of the second image
It will certainly fit. Whether it works or not is a different story. I'm pretty sure you will need to replace the harness and perhaps reprogram the infotainment system in order to recognize the new screen.
