WTB BOV
Trader history for Emeza (0)
Emeza
Is anyone selling or have recommendations for a good but inexpensive BOV set up. It would be for my 2019 stinger GT.
Thanks.
If you want good, it’s not going to be inexpensive. And an inexpensive BOV is not going to be good.
With that in mind, I recommend the Turbosmart Kompact series. I’ve worked for them before and have seen the quality first hand.
The BMS Tial is a great combo.
Emeza
Emeza
Has anyone worked with a HKS blow off valve before? any pros or cons?
I had the HKS on my Optima SX, I like it, good quality, great sound. On my stinger I'm running the BMS Tial BOV an love it, great quality, looks great as well, the sound of this thing is awesome....
Jkr2wld
Baytown
2019 Kia Stinger GT AWD 3.3
I went with Boomba BOV as I used to have it on my Fusion and I loved it. I've yet to listen or compare them to any other BOV in person, but as what I was told by Boomba, they aren't as sensitive nor can I hear it if I have the radio up or windows up because of the location (very front of the engine) which disappointed me but I'm living with it. They blow off loud and sound great...with the windows down. Paid $350 when they went on sale.
Mkahles
Cincinnati
How difficult is it to install the BMS Tial BOV? I’m not very handy.
It's really easy, there are 8 bolts that hold down your stock BOV & two hoses that connect to your intake pipes. Your going to remove all of those parts, then your going to connect the Tial BOV to the base that came with it, don't forget the round gasket you put in between the base an Tial. Then you take the gaskets from the stock BOV an install them on the bottom of the base for your Tial, then just reinstall your parts, just make sure you plug the holes on your intake pipes, here's a picture of my setup. I circled everything.. When you put the Banjo bolt on, make sure you put a crush washer on each side of the bolt and make sure the hole in the bolt is lined up with the part that the hose attaches to..
Welcome to the forums....
