Tpms
TPMS went off weeks ago, left rear tire down. Filled it up and read normal pressure. Yellow light won't go off. I must have looked through the owners manual for half an hour and could not find how to reset it.[?|]
Did you fill up the other three tire with air. Sometime it takes a little bit for that light to go out, atleast it did in my Optima SX that I had. The temperature probably has something to do with it, when I was stationed at Fort Drum my tires were low on pressure, it seemed like all the time an the fluctuation in temp was the culprit.
Make sure you fill your spare tire, those tires leak air.
I don't believe you need to reset the TPMS once it goes off.
U
light is still on, taking it to dealer tomorrow. they better have coffee and donuts
U
tech read the pressures as low and filled all 4 up despite me seeing normal pressures on the HID, lights off now. carry on.
What did it get down to?
Did they have coffee and donuts?
U
the left rear got down to 24 psi but the others were normal. it was extremely cold out btw. this happened in my bmw all the time, i would fill up the tires and manually reset
That low tire needed 2 more PSI to shut off the warning. LOL
