Welcome to Kia Stinger Forum, is this your first visit? Click the "Create Account" button now to join.
Register
User Tag List
Results 1 to 5 of 5
  1. #1
    5 Rep Points
    Medals
    Made First Post
    Likes Received
    Location
    Atlantic Highlands
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    anyone else slip/slide on tar strips in rain with the Bridgestone Potenza RE97AS-02 all-seasons?
    Guest-only advertisement. Register or Log In now!
    Just wondering if anyone else experienced sliding in the wet weather on lengthy tar strips with the All-Season Bridgestone Potenza RE97AS-02 18"s. I've noticed this on my GT2 and it does make me a bit nervous if I'm cornering and the car slides a bit when those strips are wet.
    -sodo
  2. #2
    turboit's Avatar
    Medals
    Made First Post
    Likes Received
    Location
    Harrisburg
    Posts
    50
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Same here. Next year I'm picking up a set of winter tires.
  3. #3
    Senior Member
    6 Rep Points snowman's Avatar
    Medals
    Made First Post Earned First 100 Posts
    Likes Received
    Location
    Allentown
    Posts
    119
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by sodo View Post
    -sodo
    If it snows a lot where you live I wouldn't run the all seasons year around. Get some Michelin Alpins.
  4. #4
    Senior Member
    24 Rep Points
    Medals
    Likes Received
    24
    Location
    Westerville
    Posts
    133
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    My Stinger didn't come with those Bridgestone tires (it has the Michelin Pilot 4). I have no experience with them, but I can imagine the asphalt sealer being slick when wet. Road markers are usually more slick than a typical road surface and they have embedded sand to improve traction and they're still slick. It is possible that the asphalt sealer strips are a low point and create a water puddle that induces mild hydroplaning at various speed levels depending on tread depth and depth of water puddle.
  5. #5
    5 Rep Points
    Medals
    Made First Post
    Likes Received
    Location
    Atlantic Highlands
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    +Turboit: thanks for the confirm, lemme know what shoes you end up buying. :)
    +Snowman: I'm in Jersey near NYC, so we don't get a ton of snow over the winter. Actually, the tires have performed adequately in the couple of snows that we have had thus far. I felt sorry for the Mustangs that I saw disabled on the side of a slight incline ramp to the parkway. Have AWD sure saved me. But I will consider the Alpine's, thank you.
    +POS VETT: I used to run Michelin Pilot's on my old Cadillac CTS and never had any issues with the slipping/sliding on the strips like I do with the Potenza's. I'll probably just run the Potenza's through their rated lifespan and then go back to the tried/true Pilots. The slipping is just odd and a bit disconcerting.
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
