Welcome to Kia Stinger Forum, is this your first visit? Click the "Create Account" button now to join.
Register
See the top rated post in this thread. Click here
User Tag List
Page 3 of 3 FirstFirst 123
Results 15 to 19 of 19
  1. #15
    17 Rep Points
    Medals
    Made First Post
    Likes Received
    17
    Location
    Gilbert
    Posts
    68
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Guest-only advertisement. Register or Log In now!
    I have got a years worth of oil changes from the dealership I bought the car at, which is really just 2 oil changes if you go by the service guide.
    I'm curious what they charge but there is a closer dealer to me once I exhaust these 2 freebies so I'll see what they charge.
    If you buy your own oil will Kia dealerships do the oil change for you minus the cost of the oil?
    I'll wait to see what the cost is here in AZ as I know we don't need the heavier weight oils out here. We get hot temps not cold ones. I would think 10W30 synthetic would be cheaper.
  2. #16
    Senior Member
    20 Rep Points CKeeler's Avatar
    Medals
    Made First Post Earned First 100 Posts
    Likes Received
    20
    Location
    Quail Valley
    Posts
    139
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by POS VETT View Post
    I wouldn't use RP even if it was free.
    In case of oversight, did you manage to see the bottom line?
    Yeah. What’s wrong with Royal purple. I’ve never used the engine oil. Just the manual tranny fluid and rear diff fluid. I’ve used Valvoline SynPower for the last 8 years and I love it. $25 for a 5 quart jug at Walmart
  3. #17
    Moderator
    Staff Team 388 Rep Points robz32's Avatar
    Medals
    Made First Post Earned First 100 Posts Earned First 500 Posts Earned First 1000 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points Earned First 200 Rep Points
    Likes Received
    388
    Location
    Posts
    1,414
    Mentioned
    64 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by upstatedoc View Post
    Decided to take the stinger to the dealer for its first oil change and rotation. $120. Guess I wont go there for the second.
    That's freaking outrageous!
  4. #18
    Senior Member
    22 Rep Points
    Medals
    Likes Received
    22
    Location
    Westerville
    Posts
    120
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    My opinion about RP was due to their superfluous marketing hype back when it was first introduced in the market. I have read somewhere in another forum about a racing engine builder having lubrication problems when running Royal Purple, but that was several years ago. I formed that opinion then and I have not ventured into finding new information recently. I have no personal experience regarding engine failure due to lubrication involving Royal Purple motor oil. I can imagine that nowadays their motor oils work just fine in sportbikes as proven by Spider55. I have no idea about RP gear oils or transmission fluids since I use other brands.
  5. #19
    27 Rep Points spider55's Avatar
    Medals
    Made First Post Earned First 25 Rep Points
    Likes Received
    27
    Location
    Tempe
    Posts
    64
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by MMB22 View Post
    If I go by the service guide it will take me between 12 & 18 months to get my first oil change being that I only put around 3 to 5 thousand miles a year on my car. Being here in Arizona I split my oil changes up in thirds, so every 4 months I change it. I don't care if it needs it or not. Here in Arizona the heat breaks down the oil in your car if your in traffic a lot. What I do in the summer and winter is as soon as I get home from driving anywhere is park my car in the garage an lift the hood up to let the heat in the engine bay escape, so the heat doesn't cook all the rubber and plastic pieces in the engine bay. I did that with my Optima SX and everything still looked an felt new.
    If you buy your own oil Kia will not change your oil. If you buy your own oil you will have to find a shop to change your oil.
    If my memory serves me correctly, I do be leave, you use heavier weight oil in the summer and a lighter weight oil in the winter because heavier weight oil in the winter wouldn't lubricate your engine on a cold start and your engine would have to work way to hard too pump it through the cars engine.
    Someone correct me if I'm wrong!!!!!!!!!!!
    2019 kia Stinger GT1 Ceramic Grey
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
