Welcome to Kia Stinger Forum, is this your first visit? Click the "Create Account" button now to join.
Register
See the top rated post in this thread. Click here
User Tag List
Page 4 of 5 FirstFirst 12345 LastLast
Results 22 to 28 of 29
  1. #22
    Senior Member
    25 Rep Points torbach's Avatar
    Medals
    Made First Post Earned First 100 Posts Earned First 25 Rep Points
    Likes Received
    25
    Location
    Gaithersburg
    Posts
    110
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Guest-only advertisement. Register or Log In now!
    Quote Originally Posted by roverny View Post
    Thx for the heads up. What's a TSB?
    Technical Service Bulletin.
  2. #23
    Senior Member
    Medals
    Likes Received
    25
    Location
    Gaithersburg
    Posts
    110
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    I checked my service report, and I was wrong about the sunroof issue being fixed as part of a TSB. It wasn’t fixed. Mind you, I didn’t have the issue, but I didn’t want to leave you upset with your dealer for not having a TSB. What they did fix was:
    1. SA322 rattle noise from tail gate.
    2. SC170 Front wiring harness inspection/replacement and grommet installation - recall
  3. #24
    Medals
    Made First Post
    Likes Received
    Location
    portland
    OR
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Johnnyposs View Post
    Man that sucks about the sun roof. Question,you say you plan to get pilot sport in the spring, did your not come with them? The only problem I had with Kia was with a remote start, they couldn’t figure it out for a couple of months and said they were waiting from higher HQ for a fix.
    No, they came with some Bridgestone Potenza model that aren't very good.
    Huh, weird. Did it ever get fixed?
  4. #25
    Moderator
    Staff Team 276 Rep Points MurlinatoR's Avatar
    Medals
    Made First Post Earned First 100 Posts Earned First 500 Posts Earned First 1000 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points Earned First 200 Rep Points
    Likes Received
    276
    Location
    Davenport
    Posts
    1,176
    Mentioned
    104 Post(s)
    Tagged
    2 Thread(s)
    Anyone notice how the front crash sensor only works either when you have the cruise control on or when you are in reverse? When I park in a garage I have to put in reverse and back in drive to get it to engage. It’s also notorious for going off when I park at a curb get back in to reverse and then the front sensor goes off like I’m going to hit something in the front while backing up? Anyone else?
    Hey @Johnnyposs, your's is an easy fix. As others have mentioned, the SONAR sensors are the four round dots around the front and rear bumpers. Specifically the front for your question. Now, the system will ALWAYS activate in reverse. It's programmed that way unless you intentionally hit the P> (center) button on the counsel. This system is SMART. That means that it will remember your last selection.
    The reason that it's not activating when you pull into your garage is because the system was turned OFF when in DRIVE at some point previously. So, tonight when you pull into the garage, push the button on the counsel to turn the system back ON while still in DRIVE and the system will then always activate when you have it in drive.
  5. #26
    Medals
    Made First Post
    Likes Received
    Location
    Leesville
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Yea they were kind enough to come to my house and install it since I bought it for the 4 banger model and updated to the gt2 before it arrived. I just hate how it turns off the engine once you open the doors.
  6. #27
    Medals
    Made First Post
    Likes Received
    Location
    Leesville
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Thanks man I will try that
  7. #28
    Medals
    Made First Post
    Likes Received
    Location
    portland
    OR
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by torbach View Post
    Appreciate the correction. :)
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
