Welcome to Kia Stinger Forum, is this your first visit? Click the "Create Account" button now to join.
Register
User Tag List
Results 1 to 5 of 5
  1. #1
    12 Rep Points
    Medals
    Made First Post
    Likes Received
    12
    Location
    New York
    Posts
    17
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    HELP! Tire sizing for wheels!
    Guest-only advertisement. Register or Log In now!
    Hi all, I hit a nasty pothole last night and blew out two tires--and bent not one but two wheels. I have a set of aftermarket wheels that I can use for the time being, but want to use the beefiest tire possible. The wheels are 18x8.5 +36. Can someone tell me what the largest tire size possible is that I can fit on? My Stinger is a GT AWD model and I will always be using the stock suspension.
    Thanks!
  2. #2
    Senior Member
    23 Rep Points
    Medals
    Made First Post Earned First 100 Posts
    Likes Received
    23
    Location
    Westerville
    Posts
    120
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    IMO, not wider than 245
  3. #3
    Medals
    Made First Post
    Likes Received
    Location
    Ft Wayne
    Posts
    24
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by POS VETT View Post
    Can you fit 245 up front without going too thin?
  4. #4
    Senior Member
    23 Rep Points
    Medals
    Likes Received
    23
    Location
    Westerville
    Posts
    120
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Turbochargetoy View Post
    I think so. The stock size is 225 and the lower wheel offset should allow more clearance with the strut housing. If more sidewall is desired, going with 245/45/18 provides a taller sidewall (0.7" bump in overall diameter or 0.35" bump in ground clearance) which provides more cushion against pothole impacts.
    255/40/18 can also be used to gain the same-as-stock OD, but it's not my preference.
  5. #5
    WickedStinger's Avatar
    Medals
    Made First Post
    Likes Received
    Location
    North Grafton
    Posts
    61
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Post up some pictures once you get the beefier tires on there.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
