Sting-err
Wheatleyjp
Does anyone else see the gas tank is opposite of the indicator on the display?
Probably needs to be a programming recall at some point.
lol I never noticed it until now.
And what's sad is, the one down by the fuel gauge is pointed in the right direction.
haha nice catch.
W
Wheatleyjp
When it's -10 degrees out, and you're filling up for the first time... you notice that FAST.
Glad it wasn't just mine!
Congrats on the first fill-up.[biggrin]
Thanks for pointing that out.
Stingin' Away
Dayton
2020 Stinger GT
This is not a fault or error in development. The arrow in the display, not the actual gas gauge, is pointing to the fuel pump. It's telling you how many miles until you need to go to the pump. The arrow in the actual gas gauge is correct since the gas tank is filled on the driver side, hence the left arrow. The arrow in the cluster is only pointing to the fuel pump and is not indicating which side the tank is filled from.
Hopefully that clears it up.
ditto!
I still think having the arrow there is confusing and not needed. They can still convey the same message without having the arrow.
Stingin' Away
Dayton
2020 Stinger GT
You're probably right. But remember, we are in an era where convenience is key.
Wake Forest
2020 Kia Stinger GT2 (CERSIL/RWD)
I agree completely. The last few cars I've had used the arrow to point to which side the tank is on. (The Stinger will be my 29th car :-O )
W
Wheatleyjp
Thread Starter #13
Sorry guys, every car in America has the arrow and it points to the side that the gas cap is on. My dealer is already aware, and apparently knows that a fix is in progress.
Stingin' Away
Dayton
2020 Stinger GT
What exactly are they fixing? I am by no means dumbing anything down or disrespecting you but, it is pointing to a fuel pump. A fuel pump is at a gas station. There is no correlation between a fuel pump and a gas gauge. The indicator in the display is pointing at the fuel pump at a gas station. I have never used a display to look for what side my fuel tank is filled from, only the gas gauge. Also, if the gas gauge does not have an arrow, the there will be an icon on either the left or right side of the gauge telling you what side it is filled from.
Sorry if I'm brash, I've just never had this issue before and it seems like this is an inconvenience for some when, truthfully, the answer where the gas is to be filled is right where it should be: the gas gauge.
Completely agree with you.
The screen can be changed to something else and if there is no indicator where the gas gauge is, then I can see it being a problem needing a solution. But the indicator is where is should be, the gas gauge, which the first place you would look at when checking levels or filling up.
DC
I get it for rental cars, but do you guys routinely forget which side the fuel filler door is on your personal vehicles?
olly5
Theres always an arrow next to the gas pump symbol. The arrow points to the side where the filler cap is.
Sent from my SM-N950F using Tapatalk
GA
I'm not sure why you'd be defending this so harshly, it's very well known by most people that the arrow points to the side the fuel tank is on, physically. Having two different areas with a fuel pump tell you two different directions is just not needed and unnecessary. Sure the on-screen one might be "just pointing to the fuel pump," but it is incredibly confusing to people who don't know that, and it's not explained very well by anyway (not even the manual).
Honestly, the "fix" here should be just to remove the arrow and just show a fuel pump, if they want to show it at all.
Stingin' Away
Dayton
2020 Stinger GT
#19
Drivers ed teaches, at least where I was taught, was to find the indicator in the gas gauge. If one is confused by it, they could verify with the gas gauge. Sorry if it came off harsh. Kind of common sense to most people.
Wake Forest
If the arrow was meant to be a ?distance until empty? then the graphic is in the wrong place and should read:
Range xxx miles ????
So either their grammar is wrong, or the arrow is pointing the wrong way. It is confusing (IMHO) and should point to the side of the car where the fuel cap is.
